VAC Belt pulley/Hydraulic pump
vacnewbie
10-12-2007 18:30:51
Is there a cover plate that would allow me to remove the Belt pulley/Hydraulic pump and run the tractor without it? I need to break the pump apart and rebuild it, but I want to run the tractor during that time frame. Thanks.
Bob Smith
10-13-2007 10:56:54
 Re: VAC Belt pulley/Hydraulic pump in reply to vacnewbie, 10-12-2007 18:30:51
vacnewbie
If I'm looking at it right, the Pump/pully mount on the right side of the tunnel tube and by looking at the manual on a 4 bolt mount.
My tractor has this mount but has a plate bolted over it as my hydro pump is mounted on the engine.
From reading in the manual there is a bevel gear behind this plate that drives the pump or the pulley in some cases and it appeares to me that yes you could remove this pump/pully and bolt a plate in it's place and continue to use the tractor like the way mine is right now.
Also reading in the manual on the pulley the one that dosen't have a pump built into it ( I kind of find this unique never seen one like that) you can loosen the set screw at the base of the mount next to tunnel and pull pully out to disengage the pulley so it dosen't turn when not in use? Maybe yours could be done that way also? But with it having a pump built into it I couldn't really say for sure? Something to look at?
Bob Smith
VAC newbie
10-12-2007 19:19:37
One more question...This VAC has the Belt pulley with the hydraulic pump below. The manual states how to disable the hydraulic pump. It also states how disable the belt pulley on the model without the hydraulic pump.... Is there a way to disable the belt pulley on this setup?
Bruce Nelson
10-14-2007 06:48:01
 Re: VAC Belt pulley/Hydraulic pump in reply to VAC newbie, 10-12-2007 19:19:37
On a VAC with the hydraulic pump by the belt pulley, you can disable the pump. You cannot disable the pulley. (you can disable the pulley on belt pulleys without the pump). When you have the pump, you can remove the pulley and install a cover over the pulley shaft. The cover looks like the bottom half of soup can. Case part #VTA-414. This allows you to run the tractor without the pulley, which will allow you to put the tractor in gear more quickly after the clutch pedal is depresses because you don't have to wait for the pulley to slow down and stop, at which time the transmission gears stop too, allowing a nice quiet shift into gear.
jerry s
10-12-2007 18:38:17
i am not sure if there is a way to use the tractor with the pump off my v.a.c. has the pump on the moter.If i can help you let me know good luck!
jerry
