PTO
Caseman 2
10-12-2007 12:38:57
Is there a way to tighten the PTO clutch on a CASE IH 2290? Are they like the old 30 and 70 series?
chess
10-12-2007 17:06:09
 Re: PTO in reply to Caseman 2, 10-12-2007 12:38:57
They are not same-30series were adjusted by hand. 70 an 90 series have hyd actuated clutches that are not adjustable. If yours is slipping its plates are worn or hyd pressure is not enough to keep from slipping.You need to put gage on line an check pressure when engaged.From prior posts i believe it should be 180-200psi.
chess
10-12-2007 17:05:48
