Gunk in rear housing
Bill64
10-11-2007 16:21:28
I have a roundnose 310 that was left outside with the brake cover plug missing. Water turned grease to fudge, What would be the best way to clean rear? Can it be done without disassembly?
Thanks,
Bill
Dutchman
10-11-2007 16:42:36
 Re: Gunk in rear housing in reply to Bill64, 10-11-2007 16:21:28
Bill, This is how I clean the rearend out on my Case LA...Drain it ...at least let what ever come out...leave a bucket under it over nite...then I put 5 gal of Diesel fuel in it...[ I had it up of the floor ] start it up and let it run for awhile...I used all gears...did this 3-4 times...at 15-20 mins each time....then drain and put oil in...let it drain overnite again... If you want drive it around the yard...I was in the middle of the winter There might be other ways ....it work GREAT for me.....Mark
