case 311 lift
doug58-311
10-10-2007 12:02:29
Lift is dumping fluid into rearend,works great so long as we keep adding fluid.Is this an easy fix? Please help, getting expensive.
bradley martin
10-10-2007 16:52:44
 Re: case 311 lift in reply to doug58-311, 10-10-2007 12:02:29
It is also a possibility that oil is getting by the seal on the PTO shaft. Before you tear it down, put something substantial on the hitch(like a scraper blade or bushog) and leave it in the raised position overnight. If it settles , it is the internal cylinder, if not it is the seal on the PTO drive shaft where it passes from the transmission to the rear end. Both repairs require lifting the lid of the rear end.
doug58-311
10-12-2007 11:32:07
 Re: case 311 lift in reply to bradley martin, 10-10-2007 16:52:44
Thanks, going to check on it the weekend.
BarryfromIA
10-10-2007 18:00:19
Look up the parts on the CNH site there is an updated piston for the lift. Just replaced the seals on my 312. It had the update done years ago. Parts were about $53 from CASE.
doug58-311
10-22-2007 14:52:47
 Re: case 311 lift in reply to BarryfromIA, 10-10-2007 18:00:19
Thanks for the web site . Found parts , piston and o-rings. Local Case dealer said model 311 didn't exist and to check our numbers , obviously no help there. (Dillon S.C.)
BarryfromIA
10-22-2007 19:44:03
 Re: case 311 lift in reply to doug58-311, 10-22-2007 14:52:47
You may be trying to work with an old ih dealer. I ordered my parts through a CASE construction equipment dealer that is part of the Titan dealer group here in the midwest. Also the part numbers from the CNH site were what were ordered. Some part numbers have been changed, but there is a cross reference.
doug58-311
10-24-2007 09:54:58
 Re: case 311 lift in reply to BarryfromIA, 10-22-2007 19:44:03
We got seals 3 months ago there,now we are at another dealer and got parts ordered.
JGarner
10-10-2007 12:28:42
Sounds like the piston seals on the internal lift cylinder. The differential cover has to come of and then blow the piston from its bore with shop air. I don't think the pistons seals are all that expensive. On the 311 I think they are just o-rings.
