case grain drill
Wesley Stephens
10-09-2007 17:54:01
I know this is not a tractor question, but maybe somebody here can help. I have a Case "6 inch seedmaster steel hopper drill" that I think was probably made in the late 50's. My grandfather told me years ago that it was bought to finish a job where an older drill bit the dust and wasn't used much if any after that. There is not a lot of small grain planted in our area. It has been under the same shelter all my life and my mother said she had never seen it used. I pulled it out yesterday and cleaned and lubricated it and it seemed to function wonderfully. Other than some surface rust and a bad tire it looks great. I'm going to use it to plant some rye for my cows and mule for the winter since hay is very short here in southeastern NC. The chart on the drill mentions a high gear and low gear setting, but without a manual and since no living person has seen the machine in use, I don't know where it is set. I know I can plant an acre and figure it out, but I was hoping that someone had experience with this machine. Any help would be greatly appreciated.
george md
10-09-2007 20:45:03
 Re: case grain drill in reply to Wesley Stephens, 10-09-2007 17:54:01
Wesley,
I may be able to help you, the drill I have is a
model "L" low wheel and was made in early 50's.
Case had a good metering system and didn't change
for a long time. I have the manual for this drill.
On this drill the two speed is 1 or 2 sprockets depending on the width of the drill, located on the
ends of the long drive shaft that goes across the drill.To change speed loosen drive chain and
slide sprocket over and use other one,retighten
chain. if you have fertilizer boxes the 2 speed
for them is by the clutch gear for the fertilizer
drive shaft. Unless it was changed , it should be in low
gear. It should run better than 2 bushels in low
gear .Book says 2 bushels between notch # 50 &
55. I'll send you a copy of the seed chart if you
want it , also the grass seed and fert chart.
george
Wesley Stephens
10-10-2007 03:59:38
 Re: case grain drill in reply to george md, 10-09-2007 20:45:03
The info. would be great. Thank you very much.
