primary fuel filter for 1955 case 400 diesel
Richard Herdes
10-08-2007 17:58:34
Can anywone tell me where I can purchase a primary fuel filter for a 1955 case 400 diesel, part # & etc. I have a friend who has purchased one and tells me that the filter isn't available. Is this true and if so can it be converted to something else? He said that it is a cartridge type. Any information would be helpful. Thanks
Doc Larry
10-10-2007 05:52:05
 Re: primary fuel filter for 1955 case 400 diesel in reply to Richard Herdes, 10-08-2007 17:58:34
PS - if you need the other filter numbers let me know, and I'll post them tonight after work.
Larry
Doc Larry
10-10-2007 05:50:26
By "primary filter" do you mean the small first stage filter that is mounted down low beneath the injector pump? If so, that is a metal mesh that can be cleaned. If you can still buy one, which I doubt, I'm sure it would be a dealer item and not cheap, but unless it's been damaged you should be able to use it indefinitely. If it's clogged with gum or varnish, soak it in a mixture of alcohol and acetone for a little while.
The other two filters are easily obtainable from NAPA or your Case dealer or Baldwin, etc.
Larry
LenND
10-08-2007 18:38:39
I get mine at the CaseIHC dealer, at least they had them last year. And they were the same price as any auto stores.
(sonny)
10-08-2007 18:19:53
try NAPA stores , get filters for my 300 utility & my 1030 there.
