non running Cub
Farmallb
10-08-2007 17:08:31
Ive posted before about this Cub. Well, Ive got it running after a fashion. But it dosent run very long, and dosent sound right while its running, and smokes while it is. Ive been told that there is a (glaze) on the piston. I dont know what that is or what to do about it I cleaned around the ring grooves with a wire brush, and cleaned off the carbon on top. Ive also been told if one of the top rings is reversed it wont suck up gas and run. Ive also been told if the compression isnt at least around 60+ lbs it wont run. Well, 2 of them have NO pressure, and one of the others has around 50 and the other 55
GEOMO
10-09-2007 07:01:36
 Re: non running Cub in reply to Farmallb, 10-08-2007 17:08:31
MAY BE TIME TO OVERHALL.
WITH O COMPRESSION I WOULD LOOK AT THE VALVES, ARE THEY STUCK OPEN?
Waters
10-08-2007 17:23:20
Sounds like you may need some more work. Did you install new rings when you had the pistons out? Are the cylinder walls glazed? Was there a ridge at the top of the cylinder wall at the top of the ring travel? What shape are the valves in.? The cub does have several oversized pistons and rings available if you need to bore it out. You can go up to .060 oversize pistons.
Walt Davies
10-08-2007 19:33:25
 Re: non running Cub in reply to Waters, 10-08-2007 17:23:20
I say take it to a shop and get it ready to rebuild. If you don't know anymore than what it sounds like try to find a buddy who does and can show you how to repair it. Doing this on your own with no prior knowledge of engine repair seem foolish to me. You may find a few good books on over hauling engines and study them also.
Walt PS we could spend a year here with small notes on this and that and you will never get it running as it is completely shot worn out in real bad shape.
Walt Davies
10-08-2007 19:37:26
 Re: non running Cub in reply to Walt Davies, 10-08-2007 19:33:25
One more thing I'm not trying to keep you from doing this I'm simply pointing out that we who do this for a living have years of experience and training and there is no substitute for all that. There just isn't anyway you can learn to do a complete overhaul on an engine with hit an miss help.
Walt
