VAC 12 Volt Alternator Pulley
Duane WI
10-08-2007 05:56:08
I want to convert my VAC to 12 volts. I picked up a GM alternator but the pulley is too narrow. Where do you get the right pulley?
todd hamilton
10-09-2007 07:23:12
 Re: VAC 12 Volt Alternator Pulley in reply to Duane WI, 10-08-2007 05:56:08
I left the narrow pulley on the alternator when I converted my SC. It will groove the belt a little and you will need to re-adjust but otherwise has not given any trouble. Did the conversion 8 years ago and still running the same belt. Don't adjust it very tight as it will pull hard on the water pump bearing. The alternator just needs to turn and usually will not be pulling much of a load at all.
BarryfromIA
10-09-2007 16:00:04
 Re: VAC 12 Volt Alternator Pulley in reply to todd hamilton, 10-09-2007 07:23:12
Just so you will have a wide choice of solutions, I have changed my 311b and the 210b to alternators. On the 210 I made a smaller pulley at the machine shop where I worked. On the the 311b I just used the one off the old generator, it does not charge at idle but it does the job. Both always keep the battery charged.
DKase
10-08-2007 06:12:45
The pulley off your retired generator will fit right on the alt.
amo
10-08-2007 06:06:29
i bought mine at the napa store where i bought the alternator.
