VAC overdrive?
Paul Kipfer
10-07-2007 20:27:34
Was there ever an overdrive offered for a VAC? One would make it easier to keep up on tractor rides.
Hawkeye Gold
10-08-2007 11:05:04
 Re: VAC overdrive? in reply to Paul Kipfer, 10-07-2007 20:27:34
Do they allow Cases on tractor rides? I hardly ever see one.
Blessings to you all--HG
VACLee
10-08-2007 05:50:06
If you don't mind the gearing being faster in all 4 speeds you can switch the bull and pinion gears from a VAI. That would give you another 2-3 miles per hour in 4th. This would only work on the early series with disc brakes.
mikefromiowa
10-08-2007 05:32:08
My wifes uncle is sure he knows how to build one. He want to use mine as a test. Use the belt pulley and an over center pulley running it back to the rear axle. I told him I didn't think so. The brakes on it aren't that good.
