?CASE RAKE HELP?
???HELP
10-07-2007 16:04:45
I BOUGHT A OLD CASE RAKE FOR $600 TALKED DOWN TO $550 I NEED A BEARING FOR IT AND NEW TINES ATWOODS DOSENT HAVE THE RIGHT TINES AND I CALLED CASE THE IDIOTS COULDN'T HELP ME OR ANYTHING I GUESS IT WOULD OF HELPED BUT FOR SOME REASON THERE IS NO SERIAL PLATE OR NUMBER OR ANYTHING ONLY THING THAT TELLS ME THAT IT IS CASE IS THE COLOR AND THE PERSON I BOUGHT IT FROM AND HE IS OLD AND CANT REMEMBER THE MODEL NUMBER HE NEVER USED THE MACHINE I WENT THROUGH IT CLEANED HER ALL UP AND NEW TIRES AND EVERYTHING ELSE KNOW I AM STUCK NO BEARING AND NO TINES CRAP EXCUSE ME ANY WAYS IT IS A AT LEAST 20 YEAR OLD CASE SIDE DELIVERY RAKE BUT THERE ARE NUMBERS ON THE TIRE HUBS DRIVE SHAFT PLACE LIKE THAT BUT CASE CANT MATCH ANY OF THEM OR AT LEAST WHEN I CALLED SO ANY IDEAS ON HOW TO IDENTIFY IT OR GET KNEW PARTS WHICH I DON'T CARE WHAT IT IS AS LONG AS I CAN GET PARTS ANY THING WILL BE GREAT OR I AM GOING TO SELL IT TO SOME GUY THAT WILL LET IT SIT THANKS
caseman-d
10-08-2007 18:17:40
 Re: ?CASE RAKE HELP? in reply to ???HELP, 10-07-2007 16:04:45
Look for some pwrt numbers on the rake. Getting some part numbers may help the dealer identify which rake the parts may fit. If you dealer can't do it email me with some of the numbers and I'll see what I can do.
caseman-d
caseman-d
10-08-2007 17:49:17
caseman-d
Doc Larry
10-08-2007 17:13:32
Now that you mention it (dboll), I emailed an image of my rake to a Case dealer who cares, he identified it, and emailed back a parts sheet. There are people like that still around. This is still a great country.
Larry
dboll
10-08-2007 06:47:13
I bought teeth for a #200 and #281 from Case and bar brgs. for the 281 from case then drilled the other brg. and put in zerks, find a decent case dealer!
Doc Larry
10-08-2007 06:36:54
You might look for the eagle on the gearbox casting just to make sure it's a Case. I found teeth for mine at my local implement dealer.
Larry
Tom Railsback
10-07-2007 17:15:49
Any bearing supply should be able to match the manufacturer's number as Case purchased their bearings on the open market. Valu=Bilt has rake teeth.
