Clunking VAC14 Rearend
Glenn FitzGeral
10-07-2007 14:47:19
I drove my VAC14 the 21 miles out to my brother's shed this afternoon. This is the first I operated the little tractor. I had lots of time to listen to things/look things over on the lengthy trip. The engine works very well. One problem I have not yet diagnosed is a "clunking" in the rear end with the revolution of the wheels. The faster I go, the more consistant/loud it becomes. Thus, I went pretty slow all the way. I'm wondering (hoping) if it is the brakes. They are very worn out, stiff, and have very poor return springs, etc. The left one is the only one that works at all and it is right down no the running borad before it grabs. I know the rims and axel clamps are not loose. I have so many things to do right now, I just wanted to get it inside till I have time to work on it. Are those disk brakes known to "clunk" if they are in poor condition?
Thanks, Glenn F.
mj
10-08-2007 19:48:37
 Re: Clunking VAC14 Rearend in reply to Glenn FitzGerald, 10-07-2007 14:47:19
Loose lug nuts on the wheel will cause a clunking.
tomVAC
10-07-2007 19:10:07
Glen, if it clunks in time with the wheels you may have a bull gear problem. My dads VAC had a broken tooth. Drain oil and pull pto to check.
Glenn F.
10-08-2007 06:00:44
 Re: Clunking VAC14 Rearend in reply to tomVAC, 10-07-2007 19:10:07
Not really what I wanted to hear! It will be a while before I work on it. Is the bull gear hard to change?
Thanks,
Glenn
TomVAC
10-08-2007 15:11:13
 Re: Clunking VAC14 Rearend in reply to Glenn F., 10-08-2007 06:00:44
Needs to be split in front of rear end. Bull gear comes out front. Axle needs to be pushed out with a pry bar just enough so gear can be moved forward. I did it with a floor jack and blocking under engine rear and wide front. Rears had fluid and with a loader on it. Still not too bad of a job!
TimBinWV
10-07-2007 19:27:10
Glenn,I have a 48 VAC that was working fine when I pulled the engine off it for my VAC-14,if you need rearend parts.
I'm in WV,tho!
304 751 6780,cell
