v.a.c. brakes
jerry scogins
10-07-2007 07:43:57
i wanted to see if any one knew where i could find the brakes for my v.a.c. and also how to adjust them i have am looking for the books on the teactor as well.I also want to find the hand crank to have it complete also
jerry
mj
10-08-2007 19:59:02
 Re: v.a.c. brakes in reply to spiceman16, 10-07-2007 07:43:57
Pueblo Bake and Clutch does relining Link
Manuals here - Link
mrnobody
10-07-2007 11:45:44
 Re: v.a.c. brakes in reply to jerry scogins, 10-07-2007 07:43:57
You have a choice of either band brakes or disc brakes. They are available through your local Case-IH dealer. You need to pull the brake housing to see whitch type you have. If you have band brakes,well,You'll need really deep pockets. You could try YT store on this site,I have'nt as I don't have plastic to buy online steve
VACLee
10-08-2007 05:59:20
 Re: v.a.c. brakes in reply to mrnobody, 10-07-2007 11:45:44
If you have the band type, the linings for D-10/D-12 AC will work. I put a set on ours about 4 years ago and have not had any problems. We did have to drill the shoe to fit the rivet holes in the linings. If you have the disc type most shops that rebuild clutch disc can replace the facings on them. Good luck.
