900B questions
toolz
10-06-2007 22:44:15
I don't have a manual yet- how do I check the rear end/hydraulic oil level? Also, are the 2 hydraulic remotes left and right, or top and bottom? The hoses on the top have been replaced, and match. The bottom hoses are older, and are mounted with safety releases. Thanks for your help.
toolz
10-07-2007 19:07:30
 Re: 900B questions in reply to toolz, 10-06-2007 22:44:15
Thanks, Bradley. I appreciate the reply. I found the plug. Went to hook up my plow today, and the top 2 hose couplers were different than the bottom 2. Hooked up the cylinder to the top hoses, and it worked fine. The old 900 sure has it's way with a 4-14's plow! Steers hard, though. Something wrong with the power steering. Thanks again.
bradley martin
10-07-2007 02:35:02
Hydraulic couplers are paired left & right. Rear end oil level is checked w/ 1/4" pipe plug located just behind right hd axle.
