sc 3 point
l gehring
10-06-2007 17:58:52
good evening gents, i just finished building a 3 point hitch on my 43 sc. i moved the rochshaft up off the drawbar with 2 stacks of 2.5 in. square tubing. welded studs to rear bolts that hold the draw bar frame. cut the ends off of the rockshaft arms and welded on ball joints. built my own adjustable lift links from 3/4 allthread, tubing and straps,15 1/4 in. center to center. moved the 2way cylinder from the side to under the rear end and to the left of center to clear the pto housing. this tractor has the vac type hyd pump between the mag and gov.
disced the garden and it worked great ! all the welds held. when hooked to an implement it can lift the tractor off the ground. had fun biulding this project!
