case 4x4 problems
jbinc
10-06-2007 12:52:37
i have a 2000 case 580L it is stuck on 4x4 and it won't release the fuse is good i pulled it out but it still is on 4x4 any way to disengage it
mEl
10-06-2007 15:35:32
 Re: case 4x4 problems in reply to jbinc, 10-06-2007 12:52:37
The 4x4 is spring applied hydraulically released, It will be applied anytime the engine is shut off, check for voltage at the release solenoid on top of the ps unit next to the f&r solenoids, if none check the electrical circuits involved and the switch in the dash. Does the indicator light in the switch come on when the switch is turned on? It shouldn"t be hard to troubleshoot.
case trader
10-06-2007 14:15:07
in a ag. tractor it is locked when not running jack front up w/tractor off you can't turn the wheel start up you should be able to turn the wheel that said i'm sure it operates off a electric solenoid if you are sure no juice is to the solenoid i would hope it is a stuck control valve i always say do the easy stuff first.
