VAC year determination...Photos provided
VAC newbie
10-05-2007 19:22:47
Had a few questions on the following VAC....mainly the approximate year. The serial number tag was removed when painted.
Link
mikefromiowa
10-08-2007 06:11:59
 Re: VAC year determination...Photos provided in reply to VAC newbie, 10-05-2007 19:22:47
Looks just like my '48. What is the deal with the pulley at the generator location? Is it missing?
VAC newbie
10-08-2007 12:49:08
 Re: VAC year determination...Photos provided in reply to mikefromiowa, 10-08-2007 06:11:59
Pulley is missing. I am searching for an affordable one as I write.
Jerry W
10-06-2007 19:05:31
Welcome to the world of VAC Case tractors. They are some of the greatest little tractors ever made.
If your tractor is fairly original in its' parts then it is newer than mid 1944 by the lack of the 'little pointy things' at the top rear of the grill and the top front of the side panels. It is earlier than 1950 because it still has the early PTO engagement lever.
Some things to consider when you try to figure the date:
1. Block casting number VT-328 = later block
2. Governor rod bracket on the right side behind distributor = later
3. Casting date in photo VAC_010.jpg - 6-21-45 is the casting date although it is not uncommon to see a casting a year or 2 previous to the date of manufacture because of the old practice of letting castings 'cure' outside in the weather. When I was in high school in the 60's our FFA took a field trip to the Moline plant in Minneapolis and their practice was to leave them sit for at least a year before they did any machining. Then the guy retriving it for the machine shop used to carry a big hammer and make sure that the casting has a good ring to it when he gave it a swat.
4. The little brass tag on the carburator has a date just to the left of the rivot which I think I can make out 48 for the year date of manufacture. The month should be there also. This seems to be a little out of sync with the axle casting date but.... who knows
I have seen the high pressure rock shaft lift systems on VAC tractors as new as 1950 and I have 2 1949's that still have that system. In fact, I believe that it was the rare 1949 that had the Eagle Hitch. However, by 1950 most tractors seem to have it or at least the rear axle casting to accomodate it.
Your tractor does not have the rock shaft so for the most part the pump is just an ornament. The pump is so low in volume that it cannot operate much other than the little cylinder.
I think Walt had it right as a 1947 or 1948.
Jerry
ACEd
10-06-2007 06:34:04
I take it the s/n tag is missing from the dash - otherwise subtract 4 from first 2 digits. If no tag, you can tell some info from engine s/n stamped into right side of block.
Gene Dotson
10-05-2007 22:23:51
I date the tractor as a 1947 or 1948. Has the toolbox opening on the left side and straight steering arm. No eagle hitch and with high pressure hydraulic make it older than 1949... Gene
Walt Davies
10-05-2007 20:42:51
third party image
Hi nice looking tractor to bad he didn't replace the leaking seals and gasket. the pan should be an easy one to fix.
Now what are those things on the wheels for I have never seen them but I grew up on fruit farm and never saw a row crop tractor until I was a lot older.
Walt
VAC newbie
10-06-2007 05:55:14
 Re: VAC year determination...Photos provided in reply to Walt Davies, 10-05-2007 20:42:51
I think they were some random steel wheels that he put on to cover the extra length of shaft. I have taken them of and will be moving the wheels to the widest width for stability. I would like to know what the wheels were for originally.
