case v.a.c. paint and decals
jerry scogins
10-04-2007 20:25:33
I am the proud owner of a case V.A.C the tractor runs very well and the tin work is decent. I am planning on repainting the tractor in the spring as well as put new gauges in it. i would like some in formation on my v.a.c. i know it has a white hood and a few diffrences between ones i have seen in pitures and would like to know if it is a rare tractor
jerry scogine
10-05-2007 21:19:49
 Re: case v.a.c. paint and decals in reply to jerry scogins, 10-04-2007 20:25:33
yes you do I am adding pitures of my tractor when i get them taken it is very nice and i love driving it.I will keep in mind every thing about it i also want to find out how many horse power it has it is quite amazing and may never leave jerry
watsonsgotit
10-05-2007 13:27:14
Your tractor should be solid Flambeau Red with a black starter, generator, and exhast manifold. If you are planning on having a nicely restored tractor for some time to come, don't buy cheap farm store or Case IH paint. Spend a little extra and get some good paint such as Sherwin Williams, Dupont, ppg, etc. You will be much happier in the long run. Don't forget the decals. Vinal cuts will add to the beauty.
Paul f
10-05-2007 07:14:28
I think only a few very late VACs had a Desert Sand Hood...and these were probably a dealer paint job to try to make the leftovers look like newer models
Walt Davies
10-04-2007 21:44:17
Could you put up a Pic of it and we need the serial number to check it out. the number is on the engine bell housing on the left side.
Walt
Gene Dotson
10-05-2007 03:09:55
 Re: case v.a.c. paint and decals in reply to Walt Davies, 10-04-2007 21:44:17
Not true Walt. The VAC was built in Rock Island and the tractors built there were not stamped with the number on the engine flange. Only the tag on the instrument panel contains the serial number... Gene
Walt Davies
10-05-2007 09:39:30
 Re: case v.a.c. paint and decals in reply to Gene Dotson, 10-05-2007 03:09:55
I thought that you had told me that before Gene but wasn't sure thanks for reminding me.
Walt So what's with the white paint is it just some farmers idea of being different.
Gene Dotson
10-05-2007 16:59:59
 Re: case v.a.c. paint and decals in reply to Walt Davies, 10-05-2007 09:39:30
Yeah, Walt. Have to keep you in line!!!!.. Gene
Walt Davies
10-05-2007 20:30:22
 Re: case v.a.c. paint and decals in reply to Gene Dotson, 10-05-2007 16:59:59
Gene, My 1948 LA had a desert sand hood and grill I think that it might have been painted by the owner but not real sure as it doesn't show red under it.
you sure run into some funny things on these old tractors.
Walt
Gene Dotson
10-05-2007 22:35:04
 Re: case v.a.c. paint and decals in reply to Walt Davies, 10-05-2007 20:30:22
The first tractor to use Desert Sand was the 500 diesel in 1953, then the 400 Racine.
Gene Dotson
10-05-2007 23:10:07
 Re: case v.a.c. paint and decals in reply to Gene Dotson, 10-05-2007 22:35:04
WHOA;;;
Boy did I goof up on this one. The 500 was Flambeau Red and the 600 was Desert Sand. The 400 was the first painted Desert Sand... Gene
Walter r. Davies
10-06-2007 08:58:05
 Re: case v.a.c. paint and decals in reply to Gene Dotson, 10-05-2007 23:10:07
That's what I thought Gene but I see a lot of older cases with desert sand on them. I guess people didn't like the Red and wanted it to look like the newer tractors.
Ain't this fun working on old stuff that you don't know what the last owners have done to it.
My 45 LA had the exhaust turned over and run out the bottom then the last owner turned it up right in front of the driver Boy was it hot.
Walt
