CASE VAC-MOUNTING ALTERNATOR ?
VAC newbie
10-03-2007 13:00:23
Purchased VAC with 12 volt system that is missing generator and mounting hardware. Is there a particular alternator that is best for this application? Should I look for original mounting hardware or will it not be helpful?
mj
10-04-2007 21:20:37
 Re: CASE VAC-MOUNTING ALTERNATOR ? in reply to Mr. Levi, 10-03-2007 13:00:23
'They' (Image Event) host it but it's mine. 8)
Link
tomturkey
10-04-2007 06:25:54
 Re: CASE VAC-MOUNTING ALTERNATOR ? in reply to VAC newbie, 10-03-2007 13:00:23
VAC-Newbie, Thats the great thing about this forum. The vast amount of knowledge and experience at your fingertips. I don't know where I would be without access to this asset. gobble
GEOMO
10-04-2007 05:39:49
I USED OLD STYLE GM ALT. W/ REGULATOR.
YOU HAVE TO CHANGE THE SWITCH.
LAST ALTERNATOR I BOUGHT FOR LESS THAN 30$ AND SWITCH WAS AROUND 5$
GEOMO
10-04-2007 05:39:14
Bob Smith
10-03-2007 13:41:27
Hi Newbie
Do a search for VAC 12 conversion in the Case Discussion Forum and you will find a lot of info there on converting over to 12 volt.
Good Luck
Bob Smith
Bob Smith
10-03-2007 13:47:20
 Re: CASE VAC-MOUNTING ALTERNATOR ? in reply to Bob Smith, 10-03-2007 13:41:27
Also if you are looking for information on your VAC Do a search on the web for VA Manuals on ImageEvent they have a complete Va Series Manual there and it's free for your use..
amo
10-03-2007 17:44:21
 Re: CASE VAC-MOUNTING ALTERNATOR ? in reply to Bob Smith, 10-03-2007 13:47:20
I purchased a single wire 12 volt alternator from napa and had to make a bracket to mount it and it works great.
VAC newbie
10-03-2007 18:56:12
 Re: CASE VAC-MOUNTING ALTERNATOR ? in reply to amo, 10-03-2007 17:44:21
Thanks. I had been told that by another mechanic friend as well. I just wanted to be sure that I was not reinventing the wheel by taking his approach. Ussually I get finished with a Macgyever project and the first real mechanic that walks by says that there was a $10 kit for that application....after I spent 2 days on the project. I will also be reviewing the info online now that I have a moment. Thanks again!
