Case tractor
Steve Burd
10-02-2007 18:49:56
I have, I believe, an early 60's Case 811B Serial number 8140676. It has a hydrostatic transmission. My question is: Hydraulic fluid was put into the transmission, will this work or does it require a transmission fluid? How much and what kind?
Thanks to anyone who can help.
Steve Burd
chess
10-03-2007 09:01:47
 Re: Case tractor in reply to Steve Burd, 10-02-2007 18:49:56
Dont know when change was made to combine trans an hyd oil but my 830 serial 8244092 has both hyd an trans using same oil sump .Case tch was our choice an it holds 18 gal.COM is seperate an holds 4 gal .
Jim B
10-02-2007 19:42:30
Your 811B does NOT have a hydrostatic transmission....
The 700-800 series tractors have what Case called a Case-O-Matic (COM) system. The COM is a manual shift, mechanical 4-speed+reverse/2 range (8-speed+2rev) transmission. With a torque converter instead of a manual/conventional friction-clutch driving the tranny. The torque converter has an internal lock-up hydraulic clutch which prevents slippage, sorta like a modern automobile OD trans. One difference though is within the lock-up feature, also called direct-drive, it's manually controlled using the lever on the left side of the steering column.
The operators manual calls for: 4 gallons of non-detergent 10W engine oil, labeled MS-DG, in the "Torque Converter Housing".
FYI: "Hydraulic Oil" is not even specified for the Hydraulic system! That's the 3-point Eagle Hitch & the hydraulic couplings for the remote (implement) cylinders. That system uses 10.5 quarts, with an Eagle Hitch, of Automatic Transmission Fluid (ATF), Type A.
Gene Dotson
10-03-2007 07:16:41
 Re: Case tractor in reply to Jim B, 10-02-2007 19:42:30
The 700 uses a conventional clutch and not Case-O-Matic. That is the basic difference between the 2 tractors.
You will be fine using conventional universal hydraulic oil in the Case-O-Matic and hydraulic system. Very little difference between the non-detergent and hydraulic oils. Hydraulic oil has a non-foaming additive to reduce foaming. This will also perform well with the live PTO clutch.
Original spec for the hydraulic was for type a transmission fluid, which is now Dexron-Mercon... Gene
