Case 1370 PTO
yoburt
10-01-2007 17:27:54
The PTO shaft spins even when the lever has not been moved to engage the PTO. Linkage is okay. And when shredding, when under a load at high rpm and a low gear the PTO slips and does not turn at all until you get the shredder into open air. PTO clutches at fault? Maybe the flow divider valve?
tomVAC
10-02-2007 05:51:51
 Re: Case 1370 PTO in reply to yoburt, 10-01-2007 17:27:54
Tee in a gauge between control valve and pto. If I remember right should be 180-200 psi to engage clutch.
