580 shuttle stops working after oil is hot
Daniel Rice
10-01-2007 16:45:11
My 1970 580 CK has a shuttle problem. I replaced the broken woodruff key on the pump for the shuttle. Now when ever i try to go in reverse the tractor can hardlyu pull itself and forward the tractor goes fine until the oil gets hot. If I use a heavier wight oil will that help the clutches from slipping.NEED HELP!!! Anyone have and ideas what the problem might be??
Thanks
Daniel from Pa
Jim B
10-01-2007 21:11:55
 Re: 580 shuttle stops working after oil is hot in reply to Daniel Rice, 10-01-2007 16:45:11
Perhaps the Shuttle control valve linkage got out of adjustment when you fixed the key. The spool may not be centered and a restricted flow of oil is not fully engaging the clutch.
Using a heaver oil is only treating the symptom, not resolving the problem... I wouldn't do it.
Daniel Rice
10-02-2007 14:39:47
 Re: 580 shuttle stops working after oil is hot in reply to Jim B, 10-01-2007 21:11:55
helped some what not fully
