Case 420-B-H
coolerfixer
10-01-2007 10:45:03
Just picked up this backhoe. Engine was running until it got onto the trailer. Now it's stuck. Pulled the head, loks ok. Just can't get it to turn over in any way. So I think I'm going to pull the motor (it was windowed by a rod and repaired very poorly with JB weld). My question is what is the process for seperating the block from the trans? It looks a little intimidating, but I'm sure I can handle it. Thanks in advance!
INCase
10-01-2007 12:30:40
 Re: Case 420-B-H in reply to coolerfixer, 10-01-2007 10:45:03
WIth the loader off its not too bad at all other than time to disconnect everthing. you"ll have to drain the Case-o-matic/hyd housing. I can"t remember if you had to pull the front off or not (I had the front off anyway). You may have to remove the front axle mount that is at the back of the oil pan. There was a post on here in the last 6 to 9 months asking a similar question and I think there was a trick in doing it with the loader on. Do a search and see if you can find it. I don"t recall if it was a Case-o-matic or not.
