help on 800 gas engine tolerances
INCase
10-01-2007 06:43:47
More questions. What is the crankshaft rod pin tolerance supposed to be? My I&T manual says 0.001" for out of roundness and 0.002" for taper for 30 series tractors. It lists 0.002" for out of roundness and 0.003" for taper for the 500-600-900B. What is correct for the 800?
Second question: the I&T manual does not list tolerances for the oil pump. I"m measuring 0.032" between the gears on the 800 pump. What is the spec for this?
Thank you!
Jim B
10-01-2007 21:24:45
 Re: help on 800 gas engine tolerances in reply to INCase, 10-01-2007 06:43:47
Sorry, but I don't have a Case Service manual for the '00' series to answer your question with any authority. But I'd say it should be like the 500-600-900... since it's not a 30 series.
As to the oil pump gear clearance... .032" is higher than any other clearances I've ever heard! But what was the oil pressure before the rebuild? If within normal range I'd say the pump is OK.
INCase
10-02-2007 05:25:06
 Re: help on 800 gas engine tolerances in reply to Jim B, 10-01-2007 21:24:45
I"m afraid the gage cluster is pretty bad and the oil pressure gage, amount others, isn"t working. I wonder if this, along with poor oil has caused the rattle on the #1 rod. The pump out of the 730 measures 0.016" between the gears. will swap gears out if I can get the pin out of the drive gear and shaft. I"ve had a tough time measuring the crank journals upside-down with the mics. I"m going to try plasti-gage and see what I get but still need to know the tolerances. Kinda frustrating. got it running pretty good and then heard this rattle. Wonder if its time to cut bait and look for another engine and part this one out?? That"s the life with old tractors I guess. Thanks.
