Case 530 dipstick and filler
triumph
09-30-2007 12:22:54
There is a dipstick on the lower right of the steering wheel. Please tell me what it is for and where the fill tube is. Also what kind of fluid goes here? Ken (Just an old dumb fella)
Mike in MI
09-30-2007 19:25:59
 Re: Case 530 dipstick and filler in reply to triumph, 09-30-2007 12:22:54
Ken,
I�m not sure what transmission you have or if I can give you a good enough answer? But when you mentioned the dipsticks on the lower right side of the steering wheel does your 530 have the torque converter or the triple range w/standard transmission? My 530 has the standard trans. When sitting in the seat on the left hand side below the steering wheel is a plug style/dipstick that screw in and out to check the transmission oil. There is a grove around the lower part of stick for the full mark. I have been putting 10W non- detergent oil in mine. I use the same spot to add oil in.
Also another dipstick just directly below the seat and this checks the rear differential & final drive oil. This takes 80/90W oil. I�m kind of new on the 530�s this was my dad old tractor haven�t had it all that long. I�m more into the Oliver�s tractors myself. Mike
JGarner
10-01-2007 06:07:11
 Re: Case 530 dipstick and filler in reply to Mike in MI, 09-30-2007 19:25:59
That dipstick just under the steering wheel on the left side is for the hydraulics/C-O-M(if so equipped). While the 10 oil you have been putting in probably won't hurt it you should use non foaming hydraulic oil refined for that job. The transimssion and differential on the 430/530/630 share the same heavy weight gear oil. Its dipstick is like you say, large hex head looking plug on left side under front of the seat.
