case-o-matic pto
560farm
09-29-2007 20:23:20
Hi guys,
Does the com lever need to be in direct drive or can it stay in com while doing stationary pto work? We have always had dual ranges and powershifts, I know the powershift shouldn't be in reverse when doing stationary work. I couldn't find anything specific in my 730/830 com ops book, just the general pto stuff. I will have to look at my 800 com ops book. Thanks,
Brad
Jim B
09-30-2007 20:52:15
 Re: case-o-matic pto in reply to 560farm, 09-29-2007 20:23:20
No difference which position the COM lever is in if the Tractor is stationary... which means the transmission is in neutral. Therefore no torque (load) is being transmitted thru the torque converter into the tranny.
triplerange
09-30-2007 06:04:33
perfectly ok to leave in COM drive.
BLR
09-29-2007 22:24:43
There shouldn't be a problem leaving the thing in COM. After all that is the default position. In fact my grandfather took the COM lever off his 611b so hired folks wouldn't tear it up, and we did lots of stationary spraying with it when I was a kid.
j Heitkemper
09-29-2007 20:51:32
With all My time around 800 Case O matics Never had a rule on that one ,, However I would follow same procedure of dual ranges and powershifts ,,Just a good habit to keep ,, jim
