Case 580 CK Hydraulic Cylinder disassembly
Doug Overkill
09-29-2007 17:52:49
I have 2 leaking cylinders on my 1971 580CK. I removed them both from the tractor and have removed the threaded ring that holds the piston on. The service manual says to slide the rod out but I cannot get either rod to move even a little. The tractor and both these cylinders were moving with the hydraulics. Now that they are out of the tractor I can not get them to budge. I have hooked a ratcheting come along to one of them with the other end rigid to the tractor, but no movement. I have also tried to push the rod deeper into the housing but no movement.
Am I missing something? Is there a trick or better procedure?
Thanks.
cnj152
09-30-2007 13:59:27
 Re: Case 580 CK Hydraulic Cylinder disassembly in reply to Doug Overkill, 09-29-2007 17:52:49
They are tuff sometimes. Keep pulling or make you a slide hammer of chain and weights on the chain.
bradley martin
09-30-2007 03:32:22
Are your hose openings open or did you put plugs in them to keep dirt out?
Doug Overkill
09-30-2007 05:34:56
 Re: Case 580 CK Hydraulic Cylinder disassembly in reply to bradley martin, 09-30-2007 03:32:22
All ports are open, but the rod won't budge.
Jim B
09-30-2007 21:07:03
 Re: Case 580 CK Hydraulic Cylinder disassembly in reply to Doug Overkill, 09-30-2007 05:34:56
Normally the cylinder need not be removed from machine to rebuild seals/gland packing. Leaving the housing end attached does two things... 1.Holds and keeps the cylinder housing from rotating while you remove the gland assembly. 2. hoses can remain attached and with the engine running the cylinder can simply be activated (in the correct direction) to push the piston/rod assembly out. Just don't move the control lever very much. feed the pressure slowly so as to not BLOW-it-out, for obvious reasons.
