Big power difference (with a turbo)
Roger (Mi)
09-29-2007 09:29:39
I own both a 1030 and 1070 among other Case tractors. The 1030 is still my favorite. Yes, there is a big difference in power if both have turbos installed. My 1030 with a turbo has a max of 145 horsepower with the pump turned up. I've turned it back to 125 horsepower. The 1030 power cell heads handicap the engine for potential power increases. The direct injection heads on the 1070 is a different story. With its cross flow heads, a turbo installed, and the pump turned up, 300 or more horsepower is on tap. Because of the direct injection cross flow heads on the 1070 engine, hood sheet metal work will be required. Some linkage and fuel changes will need to be made. If you want the potential of big horsepower, changing to the '70 engine is the way to go.
