Early 1370? Get the update kit!
Roger (Mi)
09-29-2007 09:06:59
Case had some problems with the 1370 power shift with bolts shearing in clutch packs. Case put together an update kit which corrected the problem. If your 1370 doesn't have the update kit already installed, make sure to request that kit at the CaseIH dealer.
tom 88
09-30-2007 06:43:56
 Re: Early 1370? Get the update kit! in reply to Roger (Mi), 09-29-2007 09:06:59
thank you i didn't know that
bobby golden
10-12-2007 16:45:15
 Re: Early 1370? Get the update kit! in reply to tom 88, 09-30-2007 06:43:56
The problem with the bolts shearing was actually a problem of assembling with oil or lube on the bolts; the loctite would not hold. Buy you some cleaner that does not leave any residue on your hand when sprayed on it. The bolts in question hold sun gear planetary in; three small bolts later updated to 1/4 in inch I believe. Anyway hold bolt with allen wrench and spray clean, BUT DO NOT TOUCH with bare hand again, oil from hands with stop loctite from working. Assemble without touching or reclean and start again. The later model powershifts went to square cut o-rings which tend to hold more pressure. If you don't get bolts in right one or two will back out and fall down between sun and planetary gears$$$$$. Hope this helps bobbyg
