stalling 2590
james from sedg
09-28-2007 19:03:00
2nd season with 3100hr 2590 beginning to have problem with engine stalling when depressing clutch pedal similar problem as kycase posted in august w2290 the higher the rpm when pushing in clutch the more likely the engine wont stall but i know that cant be right posted this message on the eve of problem starting so no diagnostics yet please all opinions welcome to get me looking in the right direction
Jim B
09-30-2007 21:16:02
 Re: stalling 2590 in reply to james from sedgwick, 09-28-2007 19:03:00
Kycase1 is correct... two clutches are applying at once, the wrong two for first gear. Several causal factors could exist. Perform a clutch pressure check as described within my post for Mr Kycase1 for his 2290.
If you don't have a Service Manual, to understand the test results, just add the results to this thread and I'll look it up for you. If you prefer to do that privately... my Email is open.
Kycase1
09-28-2007 20:44:33
What I found with my 2290 was that the C1 spool was sticking open in the valve body due to dirty oil. this will cause C1 and C4 to engage at the same time. This is assuming that the 2290 and the 2590 are the same. This is very hard on the torque limiter and will break alot of parts if not fixed I speak from experience. many $$$. Hope this helps.
LenND
09-28-2007 19:13:06
I don't know about that tractor but we had 1066 IH that had a safety switch on the clutch somewhere. If you didn't push it all the way down the starter wouldn't kick in. Maybe there is something like that shorting out on yours and killing the engine.
