Splined crankshaft 188-D
cnj152
09-28-2007 08:54:21
What part does the splined crankshaft play? I want to rebuild an engine to put into 470, but I don't have a splined crankshaft, don't want to remove the engine until ready to put rebuilt one in so I don't know if the 470 has splines or not.
Thanks Neil
Klyde
09-29-2007 05:49:59
 Re: Splined crankshaft 188-D in reply to cnj152, 09-28-2007 08:54:21
the crank is splined??? all the ones i ever worked on the only thing on the flywheel end was a pilot bearing. splines were on a flywheel insert.
Tom (Ks)
09-29-2007 14:45:54
 Re: Splined crankshaft 188-D in reply to Klyde, 09-29-2007 05:49:59
The late model pto shaft is splined into the crankshaft and the early ones (with the hand clutch lever on the left side) are not. C O M's are splined into the torque converter.
rtimg
09-28-2007 15:42:38
the spline is for a PTO shaft
