Tire pressures
kirk in ks,
09-27-2007 07:46:57
how much air do you put in an 18-4-34 tire for good ride and good wear,
to Jim B, if you out there I need help jim, guessing and fumbling around, Inside duall's are spiting water when I check the air in the valve stem, maybe loose insert's, some said valve stem hasto be vertical at top where there's no water if that's the case,And tire guage wont read right and the stem insert
act's like it wont go in all the way when i press the guage in to it?
wont even push the reading prong out,
But yet it work's good on my pickup jim,
what give's?
Do I need a certain guage for tractor tire's?
never heard of this?
seem's strange to me that a regular tire guage wouldnt work on a tractor tire's valve stem?
maybe there's something backward's somewhere?
Help me on this ok Jim,
Kirk,
PS, plus the outer one's are starting to wear and get split mark's on the outside wall's,maybe too much air?
trying to be careful;
kirk in ks,
09-27-2007 18:51:04
 Re: Tire pressures in reply to kirk in ks,, 09-27-2007 07:46:57
Hi jim
i dont have a plow or anything to pull behind the Case Im kinda wondering if Ill ever get to take it in the field and Im looking for field work as I can really use it financially right now,
I gotta fix that A/C though.
it get's hot in there without a blower and I m gonna tint the window's too to keep the temp down, i was out trying it yesterday and the tranny kinda bucked a little bit,as i went into 8th and then let the clutch out, mamybe low on fluid ill check tomorrow,
cant see in the level window's at hyd tank all dark so Ill just add then check it again and then i can see if it's ok?
kinda short dip stick for the hyd fluid.
I guess its supposewd to be all the way up so it just is below the cap,
I wish i had some land to farm on as my relatives have alot ,
but me ,,, nothing, i guess ill have to job it out untill i can get some land of my own and then it'll be sweet.
thanks alot Jim
kirk,
Jim B
09-27-2007 18:29:10
Kirk, I've mentioned to you many times... your 2670 is intended to Pull-Pull-Pull, it's a farm tractor not a Lincoln. "Ride" is not important. The "Ride" will be much more affected by the field conditions than the tire pressure. As Walt said, 10-14 PSI depending on the soil conditions.
No, you don't need a special gage to check tire pressure. As somebody told you... drive the tractor so the valve stem is at 12:00 high to check or add air pressure. Another bit of advice... Don't let the fluid get into the valve stem or the gage it may ruin the gage and perhaps make the valve leak fluid and/or air.
Radials are much better than Bias ply, same reasons and benefits as for a Car or Truck. If you ever put that Big Girl to work and want best fuel economy and productivity (acres per day) then bite-the-bullet and buy a set of 8 Redials. It will cost you more than you probably paid for the tractor. But if you ever sell it your investment will be returned.
Did you ever get the interior trim installed and the door repaired? Post harvest time is nearly here... do you have any potential customers lined-up that want Fall plowing done? That 504 Turbo sings a pretty song when she is humming at 2000 RPM under a good draft load... when you do put your 2670 to WORK your impression of the tractor will completely change... I guarantee it !!!
Walt Davies
09-27-2007 08:56:23
10 to 14 lbs. look at the tread it should be flat on the ground when properly filled. A slight ripple in the side wall won't hurt on the newer radials.
Walt
kirk in ks,
09-27-2007 16:46:01
 Re: Tire pressures in reply to Walt Davies, 09-27-2007 08:56:23
hi walt I just got your e mail and your right on about these thing's,
Ive 14 lbs in the case tires and i thought it was too much,
so i was gonna take some out then try it again,
'the ineer tires are all worn down, and Id like t
to get some for the inner rim's but i dont wanna spend alor on radial's are nylon's ok on a 4wd tractor, or should I get radial's?
the outer ones are the alliance 18-4-34's, and the iner;s are old good yrs,
I think ill run with 10 lbs for now as that seem;s to be enough,
thanks again Kirk,
Walt Davies
09-28-2007 10:45:29
 Re: Tire pressures in reply to kirk in ks,, 09-27-2007 16:46:01
Always match the tires on duals or you will put to much pressure on the outside tire if it is bigger than inner side one. Don't mix radials with bias it will only cause big problems.
Try to get two tires that match your two that you are keeping if they are newer and have more tread then put the newer ones on the inside.
Walt
