VAC14 Eagle Hitch
Glenn FitzGeral
09-26-2007 10:52:57
I have run my VAC a total of about two minutes since I bought it on Easter Sunday. I started it up to unload it, drove it over near my shop and shut it down. The next time I started it up to check things over a bit, it developed a big hole in the bottom of the radiator about 20 seconds after I started it. A big chunk of sodder came loose, hit the fan and lodged on the governor area. The radaiator was not worth repairing so I bought a new one. Tonight I will be installing it and hopefully get to operate the tractor for the first time.
Question: Is it normal/propper for the eagle hitch arms to drop when the tractor is not running. I don't know how long it took, but I know they dropped to the bottom. I have done almost nothing to this little tractor yet. Tonight I will check all fluid levels prior to start-up.
Thanks,
Glenn
Uggie
09-26-2007 13:55:23
 Re: VAC14 Eagle Hitch in reply to Glenn FitzGerald, 09-26-2007 10:52:57
It sounds to me like the leather cups or seals in piston system behind the seat are worn out. There are two ways to fix the eals. One if your are lucky to find someone who makes leather cups or go to your local hydralic dealer and have them get some o rings that fit the piston. The o rings over time have a chance of flattening out so they don't work as well as they once did. They also make a scraper made from uhmw which helps with keeping the cylinder wall clean from debris that can damage the o ring and helps maintain the pressure need to keep the arms up. This is what I do to all my tractors and it works for me. None of them fall over time. Since they are worn out the oil bypasses the rings and drops to the front side of your eagle hitch. There is a 1/4" over flow drain line coming from your eagle hitch just above the floor plate on the right side of your hitch. To test to see if you are loosing pressure you can take the line off and put a can under the line and see if it makes a mess in the can. If the arms are up and the next day you can try something else but I think I will be close with my answer. Good luck
Case38man
09-26-2007 11:33:39
Glenn the VAC 14 is a nice tractor . My grandson has one but it doesn't sit long at any time ,maybe a week at a time and it does not go down. third party image
