Calling Louisville Ohio
bradley martin
09-25-2007 16:47:05
I have been thinking about your 430 Diesel that won't start. Assuming the timing is correct, fuel is good and pump has been rebuilt the only thing other than compression that might be amiss would be the air supply. Check your air intake is clear....infact, disconnect the air cleaner and give it a spin. If it has been sitting for a while, no telling what could have built a nest or even have over filled oil bath aircleaner with rainwater. Good luck.
louisville ohio
09-25-2007 19:21:16
 Re: Calling Louisville Ohio in reply to bradley martin, 09-25-2007 16:47:05
hi Thanks the intake is open i also checked return line to tank is returning fuel at this point Im trying to find a diesel mechanic to dbl check what I have done and hopefull confirm either it needs rings or I did something wrong thank you feedback is appreciated . How much pressure should the return have ??
Larry Neohio case
09-26-2007 05:47:36
 Re: Calling Louisville Ohio in reply to louisville ohio, 09-25-2007 19:21:16
Hey Louisville it sounds like you and I maybe fighting the same battle. I have a 801B and just got it to turn over last night but it wouldn't start. I may have a manual that could help you out. E-mail me at [email protected] so that we can talk. Oh and by the way I live pretty close to you in Atwater about 5 miles north of Alliance
