Case 5140 front differential under pressure
fullbore1965
09-25-2007 15:35:45
I have a Case 5140. I went to inspect the front differential fluid. I removed the fill plug and it blew out of my hand and blew oil all over the place. I found the pressure / vent and removed it. I seemed like it was under pressure as well, there was a lot of mud around it perhaps prohibiting its movement. Shoud the front end be under pressure, has anyone had experience with this?
Thanks..
case trader
09-27-2007 04:56:18
 Re: Case 5140 front differential under pressure in reply to fullbore1965, 09-25-2007 15:35:45
press. should escape through vent not uncommon to see vent plug as you said i see it some in my over the road trucks really hard on seals
