Case 430
R.F.W.
09-25-2007 07:10:11
I am a proud owner of a 1965 case 430 tractor [Diesel] with a bucket. the bucket has a one way lift cylinder and comes down by gravity the bucket tips with a two way cylinder question can this tractor lift system be changed to a two way lift system also the bucket when left in an up position will fall down over a time span of several hours my cylinders do not seem to have fluid leaking from no leaks at the hoses can the pump have a slow leak?? Thanks a lot for all help . Have a safe good day. Barney
triplerange
09-25-2007 09:59:43
 Re: Case 430 in reply to R.F.W., 09-25-2007 07:10:11
Probably getting some internal leakage at the valve. If the arms go up slow the first time after it has set for a while, the cylinders could have an internal leak. Hope this helps.
