800 converter cooling pressure
Roger Roemen
09-24-2007 18:23:54
How much pressure is there in the lines going to and from the radiator to the converter. It doesn't seem like there should be very much, but I can't find a source.
Roger Roemen
09-25-2007 06:09:16
 Re: 800 converter cooling pressure in reply to Roger Roemen, 09-24-2007 18:23:54
Is that the pressure that goes through the radiator?
J heitkemper
09-25-2007 20:13:38
 Re: 800 converter cooling pressure in reply to Roger Roemen, 09-25-2007 06:09:16
Yes .. runs thru a honeycomb of 3 pipes ,, Water and Trnny fluid should not intermix
j HEITKEMPER
09-24-2007 19:14:54
AROUND 185 PSI ,,TRANNY WILL PROPEL ITSELF ON 100 PSI FOR LIGHT WORK , AND MINOR RISK
