vac govenor help idles or races no in between
peter hendricks
09-24-2007 17:44:33
is there supposed to be a spring at the end of the camshaft? the balls look good with very small flat spots, does any one have a gov break down I can look at? thanks in advance Pete
Augie
09-25-2007 17:56:19
 Re: vac govenor help idles or races no in between in reply to peter hendrickson, 09-24-2007 17:44:33
No spring up there. Flat spots on your balls are bad. Also bad if the front cam bearing gallery is plugged, thus no oil to the governor. More likely the linkage is binding. Did you replace the Torrington bearing at the top of the pivot arm in the timing cover?
mikefromiowa
09-25-2007 05:34:57
Try looking Link. there should be a diagram in the engine section.
