Installing DC4 axle (see pictures)
grapefarmer
09-24-2007 09:42:26
Ok, I am now sure this is a DC4 axle, so what other items do I need to attach it to my DC3? There must be some type of bracket that goes from the wish bone to the oil pan.
third party image
third party image
third party image
third party image
caseman-d
09-24-2007 20:57:58
 Re: Installing DC4 axle (see pictures) in reply to grapefarmer, 09-24-2007 09:42:26
third party image
Thanks for posting the pictures. I have a DC-4 with bad engine and missing hydraulic pump. Been thinking of putting the front end of the DC-4 under one of my DC-3s. Thought I would convert my foot clutch to a DC-4
caseman-d
Newton Miller
09-24-2007 15:31:02
i have a NOS bracket that bolts to the oil pan. i also have a complete DC4 frontend with the heart shaped front casting. both are for sale
j Heitkemper
09-24-2007 19:20:54
 Re: Installing DC4 axle (see pictures) in reply to Newton Miller, 09-24-2007 15:31:02
Newton miller , Give Me a Call after 8 pm , 812 969 2123
Tom Railsback
09-24-2007 10:56:13
You need a riser block to go between the axle and the front casting under the radiator; I think John Saeli sells them. Otherwise, the front end will tilt down and your oil will run to the front of the pan. You also need part 4840A to attach the rear to the oil pan.
Look at page 122 of the Eagle Hitch D/DC parts book on the CaseNH website.
Mathias NY
09-24-2007 10:52:01
Is this what you are looking for?
grapefarmer
09-24-2007 11:58:09
 Re: Installing DC4 axle (see pictures) in reply to Mathias NY, 09-24-2007 10:52:01
From an early post I did, I thought that piece was to put a Case D axle on a DC, as the D and DC4 axles look a like, but the D axle is just not a tall.
Also still looking for the bracket to hook it up to the oil pan.
-Dave
SDLars
09-25-2007 06:32:48
 Re: Installing DC4 axle (see pictures) in reply to grapefarmer, 09-24-2007 11:58:09
Take a look at the two wishbones shown in the parts book. The D wishbone is straight while the DC4 wishbone is bent upwards to allow for the added height from the riser block. From what I see on your photos it looks to me like you have a D front end. If it is a D, when you come to attach the rear of the wishbone to the tractor, you'll be about two inches low unless you have alot of wear in the bolster.
grapefarmer
09-25-2007 08:34:18
 Re: Installing DC4 axle (see pictures) in reply to SDLars, 09-25-2007 06:32:48
SD,
Looking at it you could be right. I think I will do a trial fit and see how things line up.
-Dave
grapefarmer
09-24-2007 13:43:40
Tom,
Thanks for the case lookup page. The parts list shows what I need. I may need the riser that Mathias posted, if my tractor before SN 8025740. Also, the picture of the axle shows the D spindle on the the left and the DC spindle on the right. Shows they used the same axle.
third party image
third party image
Tom Railsback
09-24-2007 13:46:44
 Re: Installing DC4 axle (see pictures) in reply to grapefarmer, 09-24-2007 13:43:40
Dave:
The part Mathias showed is the one John Saeli sells.
