VaH brakes
woodrow231
09-23-2007 20:23:41
I am looking at a 1948 case Vah. The owner says it has no brakes. Where can I find some should I decide to buy it. Other sources for parts??
ACEd
09-25-2007 18:31:15
 Re: VaH brakes in reply to woodrow231, 09-23-2007 20:23:41
depending on year, earlier were band, later were disc - not sure about commonality of parts as VAH were separate parts listing from VA/VAC/VAO and VAS were an entirely different animal.
$600-700 is a good price almost regardless of brakes and pump. I missed a running VAS for $600 - got a non-runner for $400. I bought a VAH sight unseen for $850 and was not disappointed as it was complete and runs good except for cleaning carb and a stickey clutch. Where is it - if you pass I might buy it.
Jim Yadon
09-24-2007 14:46:53
There are two probable reasons why ther aren't any brakes on the Vah. 1. The brake bans have no brake pad material left on them. 2. The more likey reason that the axles seals leak and have soaked the brake pads with oil and you can't put enough pressure on the brakes to get them to hold. I collect VAS's and Vah's and have replaced all the brake bans on all of them. Every tractor that I have done the seals have leaked and there has not been one that had any brakes on it when I bought them. The Vah brakes are a pain to fix and change, They are encased into the axle housing same as the seals. You have to remove the rear tires and the axle where it attaches the the rearend transmission. And remove the brake linkage. The hard part is finding something high enough and stable enough to take the shaking and pulling it takes to get the axle off. The bands I get relined at a local brake shop that costs around $85. They don't and won't get replacement parts at my local Case I/H dealership. Replacement seals that you can get aren't as thick as the originals were. They were approx. 1/2" thick and the the new Chicago rawide seals are approx 1/4" thick. So when I replace my seals I always buy 4seals for the axle seal and put the first seal in backwards and the second one in the correct direction. I have had better luck with the seals holding better. The old seals always damaged the axle shaft and always left about 1/8" grove in the shaft. If you put them in the way I do it allows the new seals to ride on a better and fresher location with a better chance to not leak. I would say get the Vah if the brakes are the only thing wrong with it. But you do need to have brakes.
watsonsgotit
09-24-2007 14:22:38
The brakes should be the same as a vac. If the pads are shot, any clutch rebuilding shop should be able to install new linings.
bradley martin
09-24-2007 02:38:18
Brake parts are likely available from Case IH.
woodrow231
09-24-2007 19:21:12
 Re: VaH brakes in reply to bradley martin, 09-24-2007 02:38:18
Thanks guys for the replies. I think I can get it for $600 or $700. The pump doesnt work either. I'll do some checking with my self to see if I want to tackle this thing. Overall the metal, gauges, and other goodies are in good shape. Thanks again. Will inform you of my decision.
CHinNY
09-25-2007 09:12:10
 Re: VaH brakes in reply to woodrow231, 09-24-2007 19:21:12
If you want to make a profit i am looking for a couple of VAH and VAS,I"m going to use them and don"t care about shape as i will go thought them anyways before we put them to work. Email me if interested
