30 series power steering
Ben Zelasko
09-23-2007 15:57:00
I have a 830 and also a 930, both are 67 models. Does anyone know if you can run the steering off of the main hydraulic pump and do away with steering pump? I have heard rumors of this being done but don't really see that it will work very well.
dboll
09-24-2007 09:33:31
 Re: 30 series power steering in reply to Ben Zelasko, 09-23-2007 15:57:00
you mean to do like Oliver, IH, Deere and just about everyone else had already done by the 60's!!! like mel said a flow divider with priority to steering, the ck pump should be adequate to do this, it was done old tractors with char-lynn units
TexasWren
09-24-2007 18:07:57
 Re: 30 series power steering in reply to dboll, 09-24-2007 09:33:31
I wouldn't be too hard on Case for not following the herd. They tended to be very conservative, and engineering-centered. It's all too easy to imagine an implement blowing a line and running out your tranny oil. Then you're stuck, who knows how far from home, with no steering. Does that happen very often? Probably not (especially when they upped the hydraulic system to 18 gallons), but they planned for the possibility.
dboll
09-25-2007 05:07:32
 Re: 30 series power steering in reply to TexasWren, 09-24-2007 18:07:57
I am die hard Case but I would take my 1850 Oliver or a 4020 anyday over a clumbsy 930ck
bradley martin
09-23-2007 18:32:28
Later model tractors are built this way, using the primary pump for steering as well as other hydraulic functions. However, with a 30 series, I think you would be money, time and aggravation ahead to rebuild the power steering pump. The kits are still available.
mEl
09-23-2007 18:20:33
that idea would be great if a flow divider was used right off the pump to establish flow to the steering in a priority type circuit, an adjustable flow divider properly installed and adjusted would satisfy the steering then what was left would go the tractor hydraulics
TexasWren
09-23-2007 18:11:52
Well, that's not a bad idea, if you don't mind your steering going away whenever you use the auxiliary ports. The pressure might be higher than what the steering pump puts out, too.
