830 COM Shift problem
Jb3
09-23-2007 11:06:51
I am looking to buy a pretty nice 830 COM w/a nice loader...the problem is, the current owner says it will shift alright when cold but once warmed up it won't shift into any other gears?? What would cause this? He said he used to use it quite a bit with no problems then it sat for quite a while, then after using it again these problems appeared??
Jim B
09-23-2007 21:25:29
 Re: 830 COM Shift problem in reply to Jb3, 09-23-2007 11:06:51
The hydraulic primary clutch is probably not fully disengaging. That could be because the plates are warped from overheating or the return spring is weak or broken.
The COM typically grinds the gears a little when shifting, more-so when warmed-up. But of course the tranny WILL shift.... the secret to minimize the grinding is to shift really quick from one gear to another. Since the tractor has a loader it was probably shifted alot from forward to reverse, which if not done quick will abuse the gears and the clutch.
