Case 500 tank
Howard H.
09-22-2007 21:16:18
I noticed the diesel fuel tank on my Case 500 has a small bowl or can on the right side made into the bottom of the tank. It has a couple of small pinholes rusted into it.
Is that "fixable", or will I just have to replace the tank?? Is that interchangeable with any other models??
Thanks for any advice,
Howard
caseman-d
09-23-2007 19:04:19
 Re: Case 500 tank in reply to Howard H., 09-22-2007 21:16:18
The bowl is riveted to the tank. The purpose of this is to drain water out of the tank. I had one on my 800 I guy popped the rivets and then used well nuts to bolt it back on. Problem was I took it off because it was leaking and it turned out he didn't get one off the nuts installed right and couldn't tighten it completely.
caseman-d
bradley martin
09-23-2007 18:27:51
Tank should be repairable . Remove it, drain completely, and take it to a shop that repairs gas tanks if you don't have the equipment or expertise to weld it yourself.
