430 deisel timing still wont run
louisville ohio
09-22-2007 18:02:09
thanks for all the previous help . Im 99% sure its timed right plus every variation witin pump adjustment . Ive got manuals and have lined everything up accordingly.pump was rebuilt, Injectors were rebuilt ,head was rebuilt, starter was rebuilt all professionally. Iooked all over town today and cant find compression tester for diesel but am assuming that is all that can be wrong . is there anything im missing? Thank you in advance any input greatly appreciated .
bradley martin
09-23-2007 03:26:55
 Re: 430 deisel timing still wont run in reply to louisville ohio, 09-22-2007 18:02:09
Try a sniff of either....if engine was stuck rings are likely stuck and dry. It sounds like you have spent a lot of money already on this old girl.
louisville ohio
09-23-2007 07:36:27
 Re: 430 deisel timing still wont run in reply to bradley martin, 09-23-2007 03:26:55
Yes have more invested than I wanted just to get running but if she will run it will work out .Ill try a sniff of ether this afternoon thanks much
chess
09-22-2007 18:26:44
Are you getting any white smoke out of exhaust when cranking? AQssuming compression an timing an other stuff is right an you are not getting smoke you are not getting fuel injected into engine. Remove lines at injectors an give half throttle than spin engine see if you get fuel out of lines.Always Keehands away from any high pressure leaks.
louisville ohio
09-22-2007 18:34:54
 Re: 430 deisel timing still wont run in reply to chess, 09-22-2007 18:26:44
yes I am getting white smoke out and have pulled lines off injectors and am getting fuel Thanks
chess
09-22-2007 20:02:11
 Re: 430 deisel timing still wont run in reply to louisville ohio, 09-22-2007 18:34:54
Was engine just overhauled or does it have lot of hrs. You may have said earlierbut if so i didnt catch iT. Since you ade getting smoke it seems as tyming is probably correct-at least not 180degrees off.Dou you think starter is spinning it fast enough?Have valves an seats ever been ground ? If so this could have lowered compression so you are on right track wanting to check compression.Have you tried a very small sniff of ether.?
louisville ohio
09-22-2007 20:19:00
 Re: 430 deisel timing still wont run in reply to chess, 09-22-2007 20:02:11
havent tried ether ,engine has a lot of hours was stuck when i got it been trying to get it running so I can asess rest of tractor tranny rear end hydraulics so forth to determine if it is worth saving thanks
louisville ohio
09-22-2007 20:17:36
chess
09-23-2007 20:14:03
 Re: 430 deisel timing still wont run in reply to louisville ohio, 09-22-2007 20:17:36
Not what you want to hear but since you said engine was stuck an as Bradley Martin said you have stuck rings an that is giving you no compression causing it not to start. Might as well bite bullet an give a complete overhaul.Least check over parts an new rings at minimun.
