Case 530 flywheel
Ralph Dewar
09-22-2007 16:03:55
I have the flywheel redone ans the machinist removed the bearing and seal but did not replace it. I got a new bearing and seal but I"m not sure which side they go on. It seems that the bearing goes on the clutch side and the seal on the motor side but if somone could verify that for me I would really appreciate it.
MBR,
Ralph
Ralph Dewar
09-30-2007 13:11:03
 Re: Case 530 flywheel in reply to Ralph Dewar, 09-22-2007 16:03:55
Denni;
I have another problem. The local dealer could or would not tell me which way the clutch goes!! It is not stamped either. DOes the flat surface go flywheel side or trans side?
Regards,
Ralph
Ralph Dewar
09-25-2007 06:57:43
Dennis;
Thanks very much for the good info. I did not see the second A-37647 seal when I dismantled it so now I should be able to do it properly. I also had trouble lining it up as the bolts only go 1 way as I'm sure you know. I did not have any mark for reference. Should be good now.
Thanks again,
Ralph
Dennis/Ohio
09-24-2007 02:04:57
Hello,
Dry Clutch:
Seal A-37647 on trans side of flywheel
Engine side: snap ring,then bearing T-17389,then ring seal A-37646.
