vac throttle cable where does one get them.
Farmer Jack
09-22-2007 12:16:41
I am looking at buying a VAC tractor with eagle hitch. It has the sawtooth hand throttle but lacks the assembly to connect it to the governor. My local dealer says they're discontinued. Is there another source for these?
thanks,
Jack
515-795-4099
DARDAN
09-22-2007 22:38:56
 Re: vac throttle cable where does one get them. in reply to Farmer Jack, 09-22-2007 12:16:41
Jack;Are you refering to the hardware that bolts to the side of the engine above the distributor that supports the throttle rod and connects to the governor spring? Looks about like a generator bracket and acts as a stop for the nut on the throttle rod.
amo
09-22-2007 18:11:59
go to we site vintagetractors.com and then to engine parts and scroll down to the bottom, very good guy to deal with. Good luck.
