430 DIESEL TIMING
louisville ohio
09-21-2007 13:39:46
short of taking the head or oil pan off how can i tell when engine is on compression stroke cant get to run and i dont think I AM TIMING RIGHT
Roger (Mi)
09-22-2007 05:12:47
 Was the injection pump removed? in reply to louisville ohio, 09-21-2007 13:39:46
It's possible to install the fuel injection pump and have it 180 degrees out of time. When the engine is set on #1 compression sroke, it's set at 4 degrees before top dead center, the two lines in the injection pump window must be adjusted to be in line. All of the following advice is good.
bradley martin
09-22-2007 03:32:46
 Re: 430 DIESEL TIMING in reply to louisville ohio, 09-21-2007 13:39:46
Get yourself a shop manual before attempting to time a diesel!!!!
chess
09-21-2007 18:52:04
Remove valve cover an turn crank until you have both valve tappets loose on no 1 cyl.Look for tyming mark with degrees marked on flywheel or front pulley. Than time to 4-6degrees btdc.
Phil (NJ,Az,Sask)
09-22-2007 03:40:48
 Re: 430 DIESEL TIMING in reply to chess, 09-21-2007 18:52:04
Just to add to Chess's: In determining when #1 is TDC some PPL watch the action of #4, which switches between Exhaust & intake at exactly the same point, as more obvious.
JMHO
