PTO installation
Caseman 2
09-20-2007 11:33:02
I posted a question the other day, asking if you had to pull the hydraulic pump on a 62 930 W.S. to install the PTO, I got two answers saying that yes you did. I appreceiate the help. and would have pulled the pump had not the bolts on the floor pan been rusted beyond pulling. I looked at it long an hard not wanting to pull the pump. I took the bearing carrier and bearing off the clutch pack, installed the clutch pack, then the shifting fork, I bought a 1/2 inch ratcheting wrench welded an extension on it and bent it to where I could tighten the bolts on the shifting fork through the hole that is used to tighten the clutch. Takes a while but beats pulling the pump. Thanks fellows,
