Mounting VAC14 Steering Box
Glenn FitzGeral
09-20-2007 10:06:12
My 14 has play in the steering due to: one worn u-joint and play in the gearbox. I plan on working with the adjustment a little tonight.
Question: Is the gearbox supposed to be bolted down? Mine is not. It lifts up each time you turn the steering wheel.
Glenn
Joe (Wa)
09-20-2007 17:41:44
 Re: Mounting VAC14 Steering Box in reply to Glenn FitzGerald, 09-20-2007 10:06:12
The 2 holddown bolts for the steering housing are 7/8" x 2-1/4" NC.
Joe
Jerry W
09-20-2007 12:37:29
The box needs to be mounted down inside the front bolster. Big bolts - at least 5/8". If you need some measurements I have a 13 front apart right now.
Jerry
Glenn F.
09-20-2007 14:23:23
 Re: Mounting VAC14 Steering Box in reply to Jerry W, 09-20-2007 12:37:29
I was wondering about those big holes/threads. I think they're 7/8"x3". Mine looks looks like those bolts have been missing for decades...rusted threads, etc. I understand over-engineering and all but those are some pretty hefty bolts! It seems they could be half that size.
Glenn
