ROOSEMASTER DB TIMING WINDOW
JIM IL
09-20-2007 09:27:05
Can anyone tell me if both wheels inside the timing window cover of a ROOSEMASTER DB Pump are supposed to move when engine is turned over? On my 580CK only the wheel towards front of tractor moves. Can someone tell me what this means? Thanks, Jim
Tom (Ks)
09-20-2007 19:18:08
 Re: ROOSEMASTER DB TIMING WINDOW in reply to JIM IL, 09-20-2007 09:27:05
Only one turns over with the engine. If a Roosemaster pump has an mechanical advance installed, then the other "wheel" will move several degrees as you run the rpm's faster and then return to the same position as it was. So, you are OK.
ghjk
09-20-2007 19:12:26
only the front wheel should turn line up marks to time
