dboll weld the chamber shut
justincase
09-19-2007 19:10:25
Can you explain how that's done. I've dreamed about that but I never knew anyone who did it.
shawnspeed3
09-20-2007 08:22:59
 Re: dboll weld the chamber shut in reply to justincase, 09-19-2007 19:10:25
you must pre & post heat the head and weld it with a cast iron rod & flux with Oxy-acetlyne for best results...did some prototype chrystler heads a few years back and we braised the chambers smaller along with the ports so they could do some flowbech development & dyno runs....good luck Shawn
dboll
09-20-2007 05:08:42
a shop in Rock Valley,Ia did one for a friends f-20 puller, milled the ports and cut new valve seats and ta da- a hi-compression head!! NOT CHEAP!
justincase
09-20-2007 18:05:05
 Re: dboll weld the chamber shut in reply to dboll, 09-20-2007 05:08:42
Thanks... I'm guessing a longer valve was used.
